[Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
I have downloaded the plugins. I will try to look at the translation files tomorrow.
Bonjour,
Comment activer l'affichage ?
Have you tried downloading the file again?
I am getting constant error when trying to extract libFredo6 3.1A
finally got it after 5 downloads....works fine. -
fantastic work....so easy to use and effective
NEW VERSION 3.1bavailable.
It is necessary for running the upgrade to FreeScale 2.0b.see main message of this thread
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=145336#p144178Fredo
I followed the installation instructions on your pdf to the letter, and I'm rewarded with an amazing nothing. You installation instructions are unclear and inadequate
You wont get anything visible after you install libfred06. Have you installed freescale?
I take back my above post. I've got it to work now, I'm just a bit tired. On that note, well done sir
Glad to hear its working
NEW VERSION 3.1c
Needed for for FreeScale 2.0c
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 -
NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
Thank you for sharing such awesome tools! You are truly a ruby script-master!
Hello.
This is Korean language files of LibFredo6 & FreeScale.
I really love this awsome plugin.
Thanks, Fredo6!
Hello.
Thanks, Fredo6!
The 2 files seems to work, though I can't really help to check with my laptop. At least it shows up in the translation dialog box.
Does 크기 변형 means "Scaling"If other users want to try, just extract the file and
- drop LibFredo6_KO.lang into the LIBFREDO6_Dir_31 folder
- drop FreeScale_KO.lang into FREESCALE_Dir_20 folder
Thanks very much
Fred
a very useful tool, thank you very much.!
NEW VERSION 3.1d
Needed for for FreeScale 2.0d (the previous version 2.0c had a major bug).
NEW VERSION 3.1e
Needed for for FreeScale 2.0e
Fredo,
First of all many thanks for all your wonderfull plugins. You have brought SU to a new, unprecedented, level.
Of course I follow the topics on your plugins and try to be as updated as possible, because your plugins already make part of my daily/standard SU tools.
You have just released a new version of Freescale (v2.0e) and following your advise I also downloaded the new
LibFredo6 (v3.1e). For the first time, this release contains a new folder called DEFPARAM_Dir, containing 1 (text)item. But...this file is already in my plugins folder as part of the Cadspan plugin (to prepare SU models for 3D printing).
As usual it is impossible to have 2 files with identical names in one folder........
So here's my question: can I replace the cadspan-DEFPARAM_Dir with yours, without getting into troubles with Cadspan or not? Can both plugins use that same folder without problems??
I have put 'on hold' the update of your plugins upon further info from you, so please fill me in.
